Introducing an Rviz Alternative that runs SUPER FAST
A new ROS2-native, SUPERFAST visualizer written in Rust — `fastviz`
Hi everyone,
I’ve been working on a project called **fastviz**: a Rust-based 3D visualizer that runs as a native ROS2 node, built on `wgpu` and `egui`. RViz has been the workhorse of the community for many years and isn’t going anywhere — fastviz is just an experiment to see how much smoothness and headroom we can get out of a pure-Rust + GPU-native pipeline, and I wanted to share where it’s at in case it’s useful to others.
It’s at a preliminary stage — only a handful of message types are wired up so far — but the core architecture is in place and it already renders things like TurtleBot 4 in Gazebo end-to-end.
**Repo:** GitHub - ksatyaki/fastviz: Rust based HOPEFULLY superfast viz for ROS2 · GitHub
## The bits I’m most excited about
### 1. It IS a ROS2 node
No bridge, no middleware, no separate process. fastviz subscribes directly to topics via `r2r`, so there’s nothing extra to wire up between your robot and the visualizer.
### 2. The render thread never touches ROS2
The `r2r` executor runs on a dedicated thread; the renderer talks to it through an `Arc<RwLock>` with brief, write-only handoffs. The UI never blocks on DDS — frames stay smooth even when a noisy topic is flooding the graph.
### 3. GPU-accelerated via `wgpu`
Vulkan on Linux, Metal on macOS, DX12 on Windows, and WebGPU is on the menu too. Same renderer everywhere.
### 4. Revision-cached render passes
A `revision()` counter on the scene graph drives pass-level caching, so an idle scene costs ~zero CPU. Walking away from the visualizer doesn’t pin a core.
### 5. GPU-side per-entity transforms for point clouds
The point-cloud pipeline is instanced, per-entity transforms happen on the GPU, and the prepare step is revision-cached with buffer reuse. PointCloud2 streams stay cheap.
### 6. TF tree reimplemented in Rust
No `tf2` C++ dependency — TF maintenance lives in pure Rust alongside the rest of the ingestion layer.
### 7. TOML config as the source of truth
Layouts are declared in a TOML file — diff-friendly, version-controllable, and easy to commit alongside your robot’s launch config.
### 8. Polled wildcard topic discovery
Drop `“*”` into a topic list and every matching message type in the ROS graph gets auto-subscribed within about a second. Handy when you’re exploring an unfamiliar bag or sim and don’t want to enumerate topics by hand.
### 9. Per-topic QoS overrides in config
`reliability`, `durability`, and `depth` are all settable per topic from the same TOML file.
### 10. URDF support with STL / OBJ / DAE meshes
URDF parsing via `urdf-rs`; mesh loading covers STL, OBJ, and Collada. `package://` URIs resolve through `AMENT_PREFIX_PATH`, and `JointState` drives the FK.
### 11. Dev container + release Docker image
The `.devcontainer/` ships an Ubuntu 24.04 + ROS2 Jazzy image with `r2r` build deps, the Vulkan loader, and NVIDIA passthrough already wired up. A root `Dockerfile` also builds a release image you can `docker run`.
## What’s supported today (early days!)
This is very preliminary — only a few message types are supported right now:
| Topic kind | Message |
| `[map]` | `nav_msgs/OccupancyGrid` |
| `[poses]` | `geometry_msgs/PoseStamped` |
| `[pose_arrays]`| `geometry_msgs/PoseArray` |
| `[paths]` | `nav_msgs/Path` |
| `[scans]` | `sensor_msgs/LaserScan` |
| `[points]` | `sensor_msgs/PointCloud2` |
| `[tf]` | `tf2_msgs/TFMessage` |
| `[urdf]` | `std_msgs/String` + `JointState` |
`MarkerArray`, `Image`, `Imu`, `Odometry`, and friends are on the near-term roadmap. ROS2 Jazzy is the only distro currently tested.
## Try it
```sh
git clone GitHub - ksatyaki/fastviz: Rust based HOPEFULLY superfast viz for ROS2 · GitHub
cd fastviz
source /opt/ros/jazzy/setup.bash
cargo build --release
cargo run -p app – --config configs/turtlebot4.toml
Or via the dev container — open the folder in VS Code / Cursor and pick “Reopen in Container”.
## Help wanted
If you give it a spin, I’d genuinely love to hear:
- which message types you’d want supported next,
- what kinds of bags would make good benchmarks,
- any architectural input on plugins, MCAP playback, or multi-window layouts.
Issues, PRs, and “this completely broke on my robot” reports are all very welcome.
Hopefully this can grow into something useful for the community. Thanks for taking a look!
**GitHub:** GitHub - ksatyaki/fastviz: Rust based HOPEFULLY superfast viz for ROS2 · GitHub
Cough, rerun.io, cough? What you describe is almost the exact same thing just that rerun is many years ahead and has a more permissive license (Apache-2.0 instead of GPL). Did AI make it so easy to write something new that it didn’t even make sense to research whether this already existed?
I don’t understand the condescending tone.
Rerun is not a general visualization tool.
It is not a drop-in replacement for rviz.
Yes, AI made is so easy to code something. But I did my research first. This is something I did in my free time and find useful. I shared it so that others might find it useful. If you do not find it so, that is fine. But a condescending tone is not going to help anyone.
I have now updated this viz tool to support Almost all message visualization types from Rviz. Can save configs, can send goals and set initial pose for slam, etc. Please try it out! It can be installed via .deb for humble and jazzy!
