Help us make image_transport and point_cloud_transport better for Makoa!
Hi all, I’m not a maintainer of neither image_transport nor point_cloud_transport, though I’m their big user and proponent (point_cloud_transport has, in the end, origins in my lab :slight_smile: , though it has come a long way since then).
The more I use both throughout various ROS 2 distros, the more obstacles and surprises I keep hitting.
I’ve started putting together a list of issues/API differences/API inconveniences of both: Unify the APIs of image_transport and point_cloud_transport in Makoa? · Issue #434 · ros-perception/image_common · GitHub . My ultimate goal would be to sync the API of both and make it easy to use in both Python and C++. I’d like to get it as easy as changing rclcpp::Publisher for image_transport::Publisher with minimum required code changes and with as many features as the normal publisher/subscriber has (like connect callbacks). Ideally, before Makoa Mata-mata code-freeze (May '27).
Do you agree this is something worth resolving? (there will be some API-level friction caused by this).
Do you see any other issues not mentioned in my Github post? Please add them!
The proposed timeline is collecting inputs until mid November and then start with the implementation.
I am interested to participate.
I do have same ideas to improve performance that are API breaking
I’m all for it. I think it’s good to clean out things that we have been keeping around for one reason or another (#LessIsMore). Also, given the era of software development that we are in, I think that downstream users will have fewer opinions about API breakage, especially if it makes the interfaces cleaner and more intuitive.
