Hey everyone,
I’m currently doing a deep-dive hardware diagnosis on a Fetch 1501-0000 and could use some insight from anyone familiar with the proprietary power distribution logic on these boards.
Fixing to put on market f
or sale.
Current Status & Symptoms:
Power Input: I’m successfully getting 48V in to the main board. PC has been powered and verified working. The main board won’t power on the PC when switched on. No voltage reading at PC jack.
According to Fetch documentation, charger voltage input should power on the robot even with end of life batteries.
Hardware verified functional: e stop, power breaker on off switch, power button, fuses, temp sensors.
No enable voltage at pins 4 of U17 PS2492 chip. Should be powered by STM32 chip which is getting power. 48V at left side capacitors of U9 DRV8301 chip. 0.5V at right side caps.
LED Indicators: I have a solid Green LED at D44, accompanied by a blinking Blue LED at D58.
Area where U9 chip is had oily substance that seemed to be from thermal pad. Area cleaned with 99% alcohol. Cleaning shows changes in resistance to PC power pins.
The Issue: Despite having the 48V input and the green status light, I cannot get the 24V rail to activate.
Does anyone know exactly what hardware fault or missing handshake the blinking blue light indicates on this specific board? I am trying to figure out what internal safety loop is keeping the 24V rail locked out.
If anyone has hardware documentation, pinouts for the power headers, or has bypassed this specific power state before, I’d appreciate the pointers. Any interested takers welcome as well.
Thanks in advance.
