FusionCore + icp_odometry feedback loop merged into rtabmap_ros
PR #1419 was merged into introlab/rtabmap_ros last week, which was co-authored by Mathieu Labbe. It adds a TurtleBot3 Gazebo Harmonic demo showing a feedback loop between FusionCore (IMU + wheel UKF) and icp_odometry.
fusioncore_gif
The architecture is worth describing because the feedback direction is non-obvious:
/imu  ──────────────────────┐
/odom (wheel) ──────────────┤──> FusionCore (UKF)
/rtabmap/icp_odometry ──────┘    │
    ^                            │ odom -> base_footprint TF
    │                            │ /fusion/odom
    │        guess_frame_id: odom│
    └──── icp_odometry <─────────┘
             └──> rtabmap SLAM ──> map -> odom TF
FusionCore runs at 100 Hz and owns the odom frame. icp_odometry uses that frame as the initial guess for scan matching via guess_frame_id. A stable initial guess means scan matching succeeds more consistently and with lower residual error. The ICP result feeds back into FusionCore as a second velocity source (encoder2), tightening the UKF state estimate. rtabmap handles loop closure and map correction on top.
Each node tightens the other. Neither is strictly downstream.
To run it on Jazzy:
sudo apt install ros-jazzy-fusioncore-ros ros-jazzy-rtabmap-ros \
                 ros-jazzy-turtlebot3-gazebo ros-jazzy-nav2-bringup
export TURTLEBOT3_MODEL=waffle
ros2 launch rtabmap_demos turtlebot3_sim_fusioncore_icp_demo.launch.py
Full architecture notes and topic/TF table are in the demo README: https://github.com/introlab/rtabmap_ros/tree/ros2/rtabmap_demos/launch/turtlebot3/fusioncore
rtabmap_ros/rtabmap_demos at ros2 · introlab/rtabmap_ros
If you are using rtabmap outdoors with GPS, FusionCore also handles that separately: https://github.com/manankharwar/fusioncore
