Exclude platforms when releasing a package
Hi there!
I have been having some trouble with CI after releasing a package, since some dependencies are not available for Fedora (more specifically “aravis-dev”). It is not only that they are not in the rosindex, that would be an easy fix, but they are not available in the Fedora index either.
When doing the bloom-release I already get a warning saying that the dependency cannot be found and that I should only proceed with the release if I am sure that it does not exist. In this case it does not exist, so I just proceed and expect that my package will not be available in Fedora machines.
The problems arises with the CI, it get almost daily emails that the builds for Fedora are failing, which is to be expected. Is it possible to deactivate those CI jobs for Fedora platforms? What is the best practice in these cases? I think for ROS1 it was possible to add packages to a black-list.
It only happens in Kilted, for Jazzy I do not get any emails.
Thanks in advance.
Cheers!
Our package lvr2 relies on the embree library. This library is not existing in the rosdep index on the specific target Ubuntu 22 (ROS humble), Arm64. The quickest solution was to blacklist the package from being build on that specific target platform by opening a PR like this: Blacklist lvr2 package from being build on Ubuntu 22 arm64 by JustusBraun · Pull Request #361 · ros2/ros_buildfarm_config · GitHub
Greetings, Alex
Hey Alex,
thanks, that is very helpful.
Cheers.
