Docker compose -f docker/docker-compose.yaml up?
Hey everyone! Looks like we’re all in same boat now… When I try to verify my local evaluation.. I get :check_mark: Container aic-model-1 Recreated 0.2s
Attaching to eval-1, model-1
model-1 | ZENOH_CONFIG_OVERRIDE=connect/endpoints=[“tcp/eval:7447”];transport/shared_memory/enabled=false
model-1 | 2026-05-11T22:15:13.570143Z WARN ThreadId(06) zenoh::net::runtime::orchestrator: Scouting delay elapsed before start conditions are met.
model-1 | [INFO] [1778537713.700292521] [aic_model]: Loading policy module: nqr_policies.Johnny02
model-1 | [INFO] [1778537713.777524574] [aic_model]: Loaded policy module nqr_policies.Johnny02
model-1 | [INFO] [1778537713.778045516] [aic_model]: Using policy: Johnny02
eval-1 | [aic_engine-5] [INFO] [1778537715.471632584] [aic_engine]: Creating AIC Engine…
eval-1 | [aic_engine-5] [INFO] [1778537715.472280205] [aic_engine]: Scoring output directory set to: /root/aic_results
eval-1 | [aic_engine-5] [INFO] [1778537715.472759776] [aic_engine]: ╔════════════════════════════════════════╗
eval-1 | [aic_engine-5] [INFO] [1778537715.472780045] [aic_engine]: ║ Initializing AIC Engine… ║
eval-1 | [aic_engine-5] [INFO] [1778537715.472784568] [aic_engine]: ╚════════════════════════════════════════╝
eval-1 | [create-4] [INFO] [1778537715.476592654] [ros_gz_sim]: Requesting list of world names.
eval-1 | [aic_engine-5] [INFO] [1778537715.478450213] [aic_engine]: Successfully parsed trial ‘trial_1’
eval-1 | [aic_engine-5] [INFO] [1778537715.478520981] [aic_engine]: Successfully parsed trial ‘trial_2’
eval-1 | [aic_engine-5] [INFO] [1778537715.478547925] [aic_engine]: Successfully parsed trial ‘trial_3’
eval-1 | [aic_engine-5] [INFO] [1778537715.478552603] [aic_engine]: Successfully parsed 3 trial(s)
eval-1 | [aic_engine-5] [INFO] [1778537717.944418116] [aic_engine]: ╔════════════════════════════════════════╗
eval-1 | [aic_engine-5] [INFO] [1778537717.944423573] [aic_engine]: ║ Starting AIC Engine Run ║
eval-1 | [aic_engine-5] [INFO] [1778537717.944427436] [aic_engine]: ║ Total Trials: 3 ║
eval-1 | [aic_engine-5] [INFO] [1778537717.944431812] [aic_engine]: ╚════════════════════════════════════════╝
eval-1 | [aic_engine-5] [INFO] [1778537717.944436582] [aic_engine]:
eval-1 | [aic_engine-5] [INFO] [1778537717.944441663] [aic_engine]:
eval-1 | [aic_engine-5] [INFO] [1778537717.944445426] [aic_engine]: ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
eval-1 | [aic_engine-5] [INFO] [1778537717.944450351] [aic_engine]: Trial 1/3: trial_1
eval-1 | [aic_engine-5] [INFO] [1778537717.944454956] [aic_engine]: ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
eval-1 | [aic_engine-5] [INFO] [1778537717.944459891] [aic_engine]: → Starting trial ‘trial_1’…
eval-1 | [aic_engine-5] [INFO] [1778537717.944465155] [aic_engine]: Checking participant model readiness…
eval-1 | [aic_engine-5] [INFO] [1778537717.944490560] [aic_engine]: No node with name ‘aic_model’ found. Retrying..
eval-1 | [aic_engine-5] [INFO] [1778537848.762392087] [aic_engine]: No node with name ‘aic_model’ found. Retrying…
eval-1 | [aic_engine-5] [INFO] [1778537947.096727792] [aic_engine]: No node with name ‘aic_model’ found. Retrying.. … Even in local I can not seem to debug the “WHY IS THIS FAILING”? lol?
