[Discussion] Why Vision-Guided Robots Still Fail in Production Even When Detection Works
Hi, guys
I developing diagnostic programs around whether the command stream, feedback stream, timing window, and physical responses in ROS remain consistent, with a lightweight experimental software package named ros2_kinematic_guard . I have identified recurring issues in the vision‑guided assembly system:
The robot “sees correctly” — but the executed grasp/pose slowly diverges from the expected state over time.
This seems especially common in setups involving:
  • RealSense D435i
  • TF-based grasp pipelines
  • MoveIt servoing
  • RGB-D pose estimation
  • asynchronous ROS2 nodes
Typical symptoms observed:
  • hand-eye calibration gradually becoming inconsistent after thermal drift
  • grasp points oscillating despite stable detections
  • TF trees remaining valid while pose execution becomes unstable
  • frame timestamp mismatch causing “see correctly, grasp incorrectly”
  • retry/relocalization logic amplifying small pose residuals
Interestingly, most systems still “look healthy” from standard monitoring:
  • bbox/confidence remain high
  • TF graph exists
  • topics publish normally
  • planners succeed
…but the physical execution path drifts.
Therefore, I intend to adopt a lightweight residual monitoring method from ros2_kinematic_guard , which focuses on three indicators:
1. Pose Residual Drift
Monitoring divergence between:
expected_pose(t)
vs
executed_pose(t)
over time.
Especially useful for detecting thermal/mechanical calibration drift.
2. Temporal Coherence Residual
Tracking timestamp alignment between:
  • image frame
  • TF transform
  • depth frame
  • grasp pose generation
to detect async ordering issues.
3. Action Stability Residual
Detecting oscillation/jitter in generated grasp points or servo actions across adjacent frames.
This catches cases where the vision system is technically “working” but unstable under lighting/reflection disturbances.
The key idea:
Instead of asking:
“Did perception succeed?”
we ask:
“Did the system state remain converged throughout the perception → planning → action path?”
Curious if others in production robotics are already monitoring these kinds of residuals.
Especially interested in:
  • vision-guided assembly
  • dynamic calibration compensation
  • ROS2 observability
  • VLA/VLM action stability
  • production deployment diagnostics
