Background
I am evaluating Open-RMF for a dense industrial production environment similar to a semiconductor fabrication facility.
The environment contains:
Many AMRs operating simultaneously
Long and narrow bidirectional corridors
Bottleneck sections that can accommodate only one or two robots
Limited passing and pull-aside space
Robots dynamically entering the traffic system
Frequent route overlap, negotiation, stop-and-go behavior, and deadlock risk
In this type of environment, minimizing the travel time of each individual robot is not the main objective.
We can accept longer travel distances and additional travel time if the overall traffic flow becomes more stable.
Problem
When routes are strongly biased toward minimum travel time, multiple robots tend to select the same shortest corridors.
This causes traffic to concentrate at bottlenecks and leads to:
Repeated head-on conflicts
Frequent negotiation
Excessive waiting near narrow corridors
Oscillating route decisions
Local congestion spreading to other areas
Increased probability of deadlock as more robots enter the system
Negotiation can resolve some individual conflicts, but it occurs after robots have already selected conflicting routes.
For dense and predictable industrial traffic, I believe many conflicts should be prevented during route planning and corridor admission rather than handled repeatedly through negotiation.
Desired behavior
The traffic system should:
Prefer a longer route when the shortest route is expected to become congested
Distribute robots across alternative corridors
Penalize routes that substantially overlap existing itineraries
Avoid opposite-direction entry into narrow corridors
Reserve bottlenecks before a robot enters them
Limit the number of robots admitted into a constrained area
Use designated holding points when access is temporarily unavailable
Replan only the affected group of robots when traffic conditions change
Use negotiation mainly as a fallback for unexpected conflicts
A possible route evaluation function could be:
route_cost =
travel_time
+ predicted_lane_occupancy
+ route_overlap_cost
+ opposite_direction_conflict_risk
+ bottleneck_entry_cost
+ expected_waiting_time
+ negotiation_risk
+ deadlock_risk
The weights could be configured so that traffic stability is prioritized over minimum travel time.
Possible architecture
My current assumption is that a robust solution would require several cooperating layers.
1. Schedule-aware route planning
The planner generates multiple feasible route candidates and evaluates them against committed and predicted traffic.
A slightly longer route should be selected when it significantly reduces future conflicts.
2. Bottleneck reservation and admission control
Narrow corridors should be treated as shared resources.
The system should be able to:
Reserve a corridor direction
Prevent opposite-direction entry
Limit the number of admitted robots
Queue robots at appropriate holding points
Release the reservation after the corridor is cleared
3. Localized replanning
When a new robot enters or a substantial delay occurs, the system should replan the locally affected participants rather than always keeping every existing itinerary fixed or globally replanning the whole fleet.
4. Negotiation as a fallback
Negotiation should resolve unexpected spatiotemporal conflicts, but predictable bottleneck congestion should ideally be prevented before negotiation becomes necessary.
Questions for the Open-RMF community
Is this division of responsibility appropriate for Open-RMF?
Should schedule-aware congestion avoidance be implemented in the path planner, in a separate route-candidate evaluator, or in the negotiation proposal evaluator?
Is generating multiple route candidates and evaluating them against the traffic schedule preferable to directly modifying the A* accumulated cost?
Are mutex groups sufficient for directional narrow-corridor control, or is a separate corridor reservation and admission-control mechanism required?
Is there a supported way to trigger localized replanning of the participants affected by a newly added robot?
Which parts can realistically be implemented in the legacy
rmf_trafficsystem? -
Would the next-generation Open-RMF traffic-management interfaces provide more appropriate extension points for congestion-aware planning, bottleneck reservation, and alternative traffic algorithms?
I would appreciate feedback on the recommended architecture and on how the responsibilities should be divided between graph design, path planning, schedule evaluation, corridor reservation, localized replanning, and negotiation.
