# Circular dependency within rmw\_implementation and rmw\_opensplice\_cpp
**URL:** <https://discourse.openrobotics.org/t/circular-dependency-within-rmw-implementation-and-rmw-opensplice-cpp/1065>\
**Created:** [January 5, 2017, 7:14pm UTC](https://discourse.openrobotics.org/t/circular-dependency-within-rmw-implementation-and-rmw-opensplice-cpp/1065 "2017-01-05T19:14:47Z")\
**Showing post:** 2
**Author:** ![wjwwood](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/wjwwood/32/13715_2.png) [@wjwwood](https://discourse.openrobotics.org/u/wjwwood)\
**Post date:** [January 5, 2017, 7:39pm UTC](https://discourse.openrobotics.org/t/circular-dependency-within-rmw-implementation-and-rmw-opensplice-cpp/1065/2 "2017-01-05T19:39:50Z")
This was brought up on the issue tracker too: [Opensplice RMW implementation currently broken · Issue #303 · ros2/ros2 · GitHub](https://github.com/ros2/ros2/issues/303)
I think the consensus was that this broke in some recent refactoring of the type support and that we’re not going to spend time on fixing issues with opensplice at the moment (see [ROS 2 alpha8 - #2 by tkruse - ROS General - Open Robotics Discourse](http://discourse.ros.org/t/ros-2-alpha8/548/2)).
If this matters to you, then you can chime in there or work on a fix with guidance from us where necessary.
_[View the full topic](https://discourse.openrobotics.org/t/circular-dependency-within-rmw-implementation-and-rmw-opensplice-cpp/1065)._
