# Adding phidgets\_drivers to ros-drivers
**URL:** <https://discourse.openrobotics.org/t/adding-phidgets-drivers-to-ros-drivers/889>\
**Category:** Packaging and Release Management\
**Created:** [November 24, 2016, 1:50pm UTC](https://discourse.openrobotics.org/t/adding-phidgets-drivers-to-ros-drivers/889 "2016-11-24T13:50:05Z")\
**Showing post:** 6
**Author:** ![joq](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/joq/32/72_2.png) [@joq](https://discourse.openrobotics.org/u/joq)\
**Post date:** [November 25, 2016, 9:19pm UTC](https://discourse.openrobotics.org/t/adding-phidgets-drivers-to-ros-drivers/889/6 "2016-11-25T21:19:24Z")
Martin: I created two empty repositories:
- [GitHub - ros-drivers/phidgets\_drivers: ROS drivers for various Phidgets devices](https://github.com/ros-drivers/phidgets_drivers)
- [GitHub - ros-drivers-gbp/phidgets\_drivers-release: Bloom release repository for ros-drivers/phidgets\_drivers](https://github.com/ros-drivers-gbp/phidgets_drivers-release)
You should be able to push your existing source and release repositories to them. Let me know if you find any permission problems.
Moving a released, maintained repository is a little tricky. I usually forget something. As a start, don’t forget to update:
- all the relevant `distribution.yaml` files in `rosdistro`
- `tracks.yaml` in your release repository’s `master` branch
- source and bug report links in the various `package.xml` files
Maybe someone here will remember something I’ve forgotten.
_[View the full topic](https://discourse.openrobotics.org/t/adding-phidgets-drivers-to-ros-drivers/889)._
