# A proposal for a LidarScan sensor message
**URL:** <https://discourse.openrobotics.org/t/a-proposal-for-a-lidarscan-sensor-message/53225>\
**Tags:** design, lidar, sensors, sensor\_msgs\
**Created:** [March 15, 2026, 6:35pm UTC](https://discourse.openrobotics.org/t/a-proposal-for-a-lidarscan-sensor-message/53225 "2026-03-15T18:35:16Z")\
**Showing post:** 17
**Author:** ![mattb](https://sea2.discourse-cdn.com/flex022/user_avatar/discourse.openrobotics.org/mattb/32/1676_2.png) [@mattb](https://discourse.openrobotics.org/u/mattb)\
**Post date:** [March 26, 2026, 3:29am UTC](https://discourse.openrobotics.org/t/a-proposal-for-a-lidarscan-sensor-message/53225/17 "2026-03-26T03:29:18Z")
Perhaps I was unclear. For example the LidarInfo message would be like so:
`Header header`
`# other data here`
And the LidarScan message would be like so:
`Header header`
`time lidar_info_time # refers to the timestamp of the time in the header of the LidarInfo message`
`# other data here`
Then if you get a LidarScan message you just check if you have received a LidarInfo message with a matching timestamp to lidar\_info\_time, if not you wait until you do.
Nothing ties them to being published at the same rate.
_[View the full topic](https://discourse.openrobotics.org/t/a-proposal-for-a-lidarscan-sensor-message/53225)._
